lightmap baking for complex unity scene
A public forum for discussing and asking questions about the Octane for Unity Alpha
Moderator: ChrisHekman
emn
baking works great if every scene object has its own texture map with UVs ...
but can you please explain how to bake lightmaps for complex scenes and reusable object prefabs using tiled textures?
Is it possible to group similar object into a baking group and thus render one lightmap for several objects?
Thank you
Xhed
You can combine multiple objects into a single baking group. If the baking group settings are part of the prefab, you'll need to make those per-instance.
- Rick
emn
Thank you for the info.
I set up a simple floor, 4 columns and a roof. The columns had one baking id and the floor+roof another.
(cam=baking cam to rendertarget)
I rendered to UV2 but it always rendered only a part of the object and also included the texture.
How can I calculate the lightmap only and assign it to all objects in the baking group?
p.s.: or are there other lightmap features coming up?
Xhed
New baking functionality will be available when we have a stable test release containing Octane 4.
- Rick
Return to “Octane for Unity”
