No errors when textures are missing
swordfish-sf
If I render Octane in C4D and there are missing textures, the render completes without an error, making it hard to figure out what is causing my render to look off. The C4D renderer shows errors.
I see this in both the C4D GUI as well as the Commandline.
jayroth
Try using the "Render>Add to Render Queue" command. The render queue window will report if there are textures missing. Then you can use the Texture Manager to track down what the missing maps are.
CaseLabs Mercury S8 / ASUS Z10PE-D8 WS / Crucial 64GB 2133 DDR4 / 2 XEON E5-2687W v3 3.1 GHz / EVGA 1600 P2 / 2 EVGA RTX 2080Ti FTW3 Hybrid/ Cinema 4D
Is it fast? Oh, yeah!
swordfish-sf
Thanks for the tip! The Render Queue does indeed identify the missing textures.
I still think this is an oversight though. Missing textures should result in a rendering error.
jayroth
You're welcome, glad it worked for you. Have you checked the Octane log?
swordfish-sf
I tried rendering with the log open, but it didn't say anything about the missing textures.
I just think it should behave more like the C4D renderer, which gives you messages in the GUI and on the command line and causes the command line render to fail. Would really help us use it on our farm.
Is this a reproach or wish for a feature?
swordfish-sf
aoktar wrote:Is this a reproach or wish for a feature?
I think I'd call it a bug report. Is there a specific place for me to file them?
I'd not call somethings like "BUG" which are not implemented. It can be only a feature request to me.
swordfish-sf
aoktar wrote:I'd not call somethings like "BUG" which are not implemented. It can be only a feature request to me.
Fine, where do I file my feature request?
No need, I've noted. But i think it's not possible to do in c4d's system by plugins. Maybe a different way is required.
