3ds Max render scene "SLOW"
I’m trying to evaluate Octane for my workflow in 3Ds max. I am able to texture and setup a simple scene and animate it. My only problem is when I go to render the scene. The frame renders instantly but the current task takes 1:33 min… What am I doing wrong? I looked over the manual and I can’t find any explanation for this. I’m running Max 2015.. I really want to use this plugin but it needs to save time not create time.
- paride4331
Hi TylerADC,
could you give some more information and/or screenshots?
Regards
Paride
Regards
Paride
- paride4331
Hi TylerADC,
you could take a look at this to start:
https://help.otoy.com/hc/en-us/articles ... or-3ds-max
https://help.otoy.com/hc/en-us/articles ... Cheatsheet
Octane render is progressive, you choose sample to render or if you want set sample to 160000 (as in your clip), then you should activate adapting sampling in Kernel panel.
Regards
Paride
Regards
Paride
- Attachments
- demo.zip
- (149.48 KiB) Downloaded 181 times
- paride4331
Hi TylerADC,
that's right!
Regards
Paride
that's right!
Regards
Paride
