Hi everyone,
i have a scene ( the same scene showed in this forum about mirror black reflection problem ) , render works fine in direct lighting mode , when i would like to changed to pathtracing mode : octane go out ( crash )??
my computer is a dual xeon 5650 ( 2.66Ghz ), 24 Go ram, graphic card nvidia gtx570 ( pilote 8.17.12.7061 , date07/04/2011) , win 7 pro.
Have you an idea for solve this problem?
thanks a lot _ sylvain
octane crash
ok _ i try to check the scene , i see that the problem maybe come from the mesh preview resolution, if i put a resolution at 1024*800 : pathtracing run , if i changed the resolution for example i choice digital camera with 2464*1648 ( 3.2...) octane crash in pathtracing mode? Did you observe this problem?
Thanks Roeland for your answer,
for the memory card : there is 1.2Go ...for a small resolution ( 1024*800 ) octane take 96.2of1216MB ) (i changed it in 1600*1200 resolution , octane used 117.7of1216MB) another test (2000*1400 resolution: octane used 134.3of1216MB) and if i try with 2464*1648 resolution = octane CRASH...... for the ohter possibility i don't see a Refractive Software folder install on my disk C ? _ strange , and there is not an uninstall of it?
Hi Roeland,
thanks a lot for trying to find a solution and help me on this problem!
i have downloaded a zip , so i deleted the folder and come back with an true installer, and surprise now pathtracing mode run fine with large resolution. Roeland you are a genius...
(you ask:And how many frames per second do you get when you render at 2000*1400?) in pathtracing mode 2.11MS/sec and 0.75 fps , i don't know if is it the answer that you wait?
You're welcome.
The problem was that windows by default resets the graphics card driver if any program locks the graphics card for more than 2 seconds, see this thread:
http://refractivesoftware.com/forum/vie ... =24&t=5795
Roeland
Roeland
