Hello,
I am having an issue with enabling motion blur on my octane camera. Every time I hit render the sequence crashes a few frames in with motion blur enabled but will render perfectly fine without it enabled. Not sure why.
Attached is a bug report.
Thanks!
- Mitch
Motion Blur Crashing Render
- mitchmyersofficial
- Attachments
- _BugReport.txt
- (870.11 KiB) Downloaded 131 times
Bugreport does not have enough information. Pls send me your scene if you need help or try different scenarios and isolated parts of scene until detect the issue.
Gotcha,
Attached is the c4d file.
- Attachments
- ScoreCard_Split_DumbScene.zip
- (300.47 KiB) Downloaded 158 times
Thanks! I couldn't reproduce the crash, but i think it's about missing plugins that you have used. Boolean operation could generate non-constant topology, it may be a problem with mblur.
I see, thanks for taking a quick look at it!
