Render slows down randomly
Arhitekt
Hi fellas,
I have random speed throttling - when I leave the computer for rendering without doing anything else with it, then the render times increases 4-6times. And when I am doing with the computer something at the same time, then the speed is normal as it used to be. It all started after the format. And it dosent matter how I render - using Pictures or in Render Que mode. And what interesting about that, the rendering speed restores in the middle of the que rendering if I start doing something with the computer.
Does someone else had similar problem like I have at the moment?
All the best
Arhitekt
Extra information - the temperatures are fine all the time. Have tried different drivers as well. Im using the R18.
please, try to change the Energy Saving settings of your operating system, use the maximim settings, and disable any screensaver, just leave to turn off the monitor after some minutes.
ciao Beppe
Arhitekt
Did all ready that. Nothing happened.
