Hi
I am a Newbie to Octane, thinking of coming over from Vray which I have used for many years
Mutipass is a big part of my work flow, so thought I see how Octane handlers it
I have been following In Life Thrills easy tutorials https://inlifethrill.com/octane-cinema- ... er-passes/ but my multipass will not match up with the flat tif/PSD even If the flat file is set to linear
In Vray this used to be a problem with the file adding gamma to the multipass file and I wonder If it's the same problem here?
It seems to be an easy set up and it's not far off, but I would need it to be exactly the same as the flat image (have attached my test file if helpful)
Any help appreciated
Cheers
Richard
MutipassNot Matching Flat tif (Cinema 4D)
- Attachments
- Beauty Pass.zip
- (123.61 KiB) Downloaded 190 times
