Some discovered bugs in 15.1
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
J.C
- infinite plane object disappears when enabled
- object and layer id renders blank when Render layers checkbox is turned off
- when opening old projects that had Imager turned on results in Octane imager turned off
- exported orbx file with object layers system is buggy eg. when id 1 is enabled all objects are visible not only the one with id 1
System – Windows 11
DrawFun
Hi J.C,
Thanks for your report.
These bugs will be fixed in the coming release.
Regarding the camera imager setting, it is caused by the change that merges preview/render camera imager setting into one(the preview camera imager setting is gone now). We will add a button to sync data from preview setting to solve the legacy issue.
DrawFun
Return to “Bug Reports”
