Hi
I have 4 slave PCs and when a scene gets sent to them I get around 250 Mbps transfer speed to each slave instead of 1 Gigabit speeds (not sure why. Maybe transfer of data to multiple slaves slows down the system). Do you think 10 Gb network will make a difference or since I cannot even get 1 Gb speeds at the current network there is no point to upgrade. Thanks
Gigabit network problem and 10Gb network advice
If the output from the master also is 1Gigabit per second then (1000/4=250) sounds about right to me. If you are sending to just 1 slave the speed should be the full 1000 megabit per second. Otherwise you have a bottleneck somewhere like a router or switch.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
ThanksZay wrote:If the output from the master also is 1Gigabit per second then (1000/4=250) sounds about right to me. If you are sending to just 1 slave the speed should be the full 1000 megabit per second. Otherwise you have a bottleneck somewhere like a router or switch.
