mix alpha
Andygraph3D
is there a node for mix a series (3 or more) of pictures on alpha channel ?
You can use a Mix texture node plugged into a Mix texture node to mix 3 texturemaps.
Andygraph3D
this is example how i want
You will probably need to use the Add Texture for that.
Andygraph3D
i need add together this textures in octane because i need animate (with dial link) the opacity to every single one texture
Andygraph3D
i found the solution in Octane thx anyway ;-)
Return to “Poser”
