OctaneRender™ for Blender 3.08 - 15.1 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions.
This is a TEST version, so be prepared to have some issues. Don't use it for production.
  • Integrate 2.79a
  • Upgrade to 3.08RC2
  • Add new passes: irradiance, light direction, volume, volume mask, volume emission, volume z depth front, volume z depth back
  • Add OSL baking camera
  • Add irradiance mode
  • Add sheen pin nodes to metal/glossy materials
  • Add new IOR for to the metallic material
  • Support geometry mesh animation modifier
FIXES SINCE LAST RELEASE
  • Remove the word Octane inside menu
  • Fix environment texture rename bug
  • Set default value of "power" in Octane Image Texture to 1.0
  • Add refresh gpu button to enable users to update gpu lists
  • Hide render layer in octane engine
  • Merge interactive/render camera imager setting into one
  • Keep compatibility with old version for response curve
  • Rename "Max samples" in Octane Render Pass Setting to "Info pass max samples"
  • Support user-customized default material(“User Preference” – “Add-ons” – “OctaneRender Engine” – “Preferences” – “Default Material Type”)
  • Do not update shader/object which is hide in "Outliner"
You can read about new features of OctaneRender™ 3.08 here:
viewtopic.php?f=33&t=63219
1. OctaneRender™ Server
Windows
Blender Octane Edition - 15.1 (2.79)
Octane Server - 15.1
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v15.1 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v15.1 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v15.1 OSX ZIP
