3.08 not work
Alex31415
during the start of the cinema produces an error
"octane is not intended to be run under a windows or contains an error..."
Did you provide min. requirements for plugin?
Alex31415
aoktar wrote:Did you provide min. requirements for plugin?
win 7 x64 pro. i7 3820 16 gb ram. and... gtx 570 :) (This computer is used only for modeling)
3.07 work great, 3.08 - not work. new standalone 4 does not work the same.
You should use 388 or higher nvidia drivers. It's noted in requirements.
Alex31415
aoktar wrote:You should use 388 or higher nvidia drivers. It's noted in requirements.
the latest drivers are installed. all very mysterious. on another similar computer all works. but not here :) I'll wait for the next stable version.
Nothing will change on next stable unfortunately. Your problem may be about your gpu. I'm not sure but it's old one.
Alex31415
I know that the old one .. but in the specification it is written that it is supported. in the next few days I'll try to replace gpu with this computer
