Version 14 problems with the boolean modifier
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
grimm
I was doing some modelling with the boolean modifier and it doesn't work right in the plugin. When I was doing a difference operation, subtracting one object from another, the faces from the subtracted object to not get created. It leaves the spot from the subtracted object empty and not filled. I can create some examples if needed. Thanks,
Jason
DrawFun
Hi Jason, would you please help us to create an example to show your problem(as post attachment or PM me)? Thanks a lot!
grimm
Hi DrawFun,
I double checked this with version 15.1 of the plugin and it appears to be working as expected. So no problems now. Thanks,
Jason
Return to “Bug Reports”
