Octane scatter issue (3.07R2)
thanulee
Hi, i have this issue with a scene when i open live viewer, scatter is not at its place and i have to turn it off and on to go to where its supposed to. I must note here that i use also a map in position for scatter (idk if that plays any role).
Will i have the same problem during render or is it only a live viewer issue? thanks.
DJTravisty
Completely normal. Final render will look like it does after you turn the scatter off and on
thanulee
Yes i have to do this everytime before i send to PV... And is not normal... Its a bug? :) thanks
Did you checked on 3.08?
thanulee
Not yet, cant switch in middle of project. I will in the end of the month, if 3.08 supports network rendering. ty
thanulee wrote:Not yet, cant switch in middle of project. I will in the end of the month, if 3.08 supports network rendering. ty
Things has been fixed on 3.08 and asking question about 3.07 will not help.
