Stereo Cube Map
Moderator: ChrisHekman
wxyz
For Gear VR Stereo CubeMap should the camera be set to stereo side by side?
Xhed
yes
- Rick
wxyz
Recorded frames don't match the PBR Viewport and the 2 eyes are not coordinated.
wxyz
Should the camera be set to panoramic? Is there a way to take a png sequence at 18432x1536 and create an ORBX file compatible with Gear VR on a pc?
ChrisHekman
wxyz wrote:Should the camera be set to panoramic? Is there a way to take a png sequence at 18432x1536 and create an ORBX file compatible with Gear VR on a pc?
Yes, the camera should be on panoramic and then set to stereo side by side.
You should be able to make a recording with the provided recorder. It should support your resolution.
I am not familliar with using .orbx with Gear VR.
Return to “Unity”
