OctaneRender™ Standalone 3.08 RC 2
abstrax
Hi all,
This is the second and hopefully last release candidate of 3.08, fixing all kinds of bugs and issues. It's also available for all 3 platforms again. If no major issues are found with this build, we will release the stable version by the end of the week or beginning of next week.
For an overview of all new features of 3.08, please read the new features thread.
We are now using CUDA toolkit 9.1 (required to support Volta), which requires NVIDIA drivers of version 387 or higher.
The offline licensing mode is still disabled in this version, but will be available again in the stable version.
Changes since version 3.08 RC 1:
  • Brought back support for Linux and OSX. Please note that on OSX Volta is not supported yet, because there is no graphics driver available which supports the current 9.1 CUDA driver.
  • Improved deep image rendering by allowing a larger tolerance for merging deep point samples when hitting a surface at a grazing angle.
  • Fixed various bugs in deep image rendering:
    • The bottom 3/4 of exported EXR files are slightly transparent.
    • If the image width is not a multiple of 4, the exported deep image contains diagonal lines with infinite values.
    • GPU failure if a render region is used and extends to the bottom of the image.
  • Fixed dispersion in specular materials (see viewtopic.php?p=332244#p332244).
  • Fixed halos and wrong brightness in PMC (see viewtopic.php?p=332238#p332238).
  • Fixed incorrect loading of HDR images that overflow 16-bit floating point numbers (see viewtopic.php?p=332369#p332369).
  • Fixed direct light contribution on back-faces of polygons with a glossy material.
  • Fixed bug where some indirect reflections are added to the refraction pass.
  • Added support for meta datas min, max, slidermin, etc. for vector, normal and point inputs.
  • Fixed crash when compiling OSL shader with unreachable code.
  • OctaneLive status is only displayed, when activated.
  • Fixed crash when the command line option --help is used.
Downloads for users with a regular license
regular version for Windows (installer)
regular version for Windows (ZIP archive)
regular version for Mac OS X (DMG image)
regular version for Linux (ZIP archive)
Downloads for users with a subscription license
subscription version for Windows (installer)
subscription version for Windows (ZIP archive)
subscription version for Mac OS X (DMG image)
subscription version for Linux (ZIP archive)
Happy rendering,
Your OTOY NZ Team
WIPEXPO
I`m first to post a replay :P :P
mitchino
Yay! OSX Subscription support! Thanks Devs.
sdanaher
Excellent. Just waiting for the C4D plugin update to support OSX too.
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
Zay
Every time I change Rendertarget the entire scene is sent to the slave again. Usually that didn't happen.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 560.94| Modo/Blender/ZBrush/Daz/Poser
grimm
Thanks for the Linux version, but unfortunately it doesn't work on my system. :( I can start Octane up and load in a scene, but when I click on the mesh, geometry group, or render target node it looks like it's started to render but nothing happens. Sometime I can get a start of an image (1 or 2 spp) but it just stops and I have to kill Octane. During this, one to three of my CPU cores will be pegged at 100%. No error messages or logs.
Jason
mac3d
Thanks for the Linux version.
Rendering does not start.
Ubuntu 16.04 64 bit
Driver Nvidia 390.25
My Computer:i7 2,6ghz ram 8gb schede video nvidia 9600tso 512mb gtx560ti 1gb mainboard asus p6t se sistema operativo:Ubuntu 14.10 64 bit
aufwind
hi,
thanks for the update.
I think there's an issue with box projection, which is present since the 3.08 test releases.
Left Side Box Projection, Right Side UV Projection
It occurs with higher bump strength values (I have other examples where it happens with values below 1)
In Version 3.07 both render fine.
Box-Projection.orbx
(4.66 MiB) Downloaded 403 times
Win7 | Gigabyte G1.Sniper 3 | I7 3770K | 2x Titan (Kepler) | 1x Titan X (Pascal)
andw
abstrax wrote: [*] Fixed incorrect loading of HDR images that overflow 16-bit floating point numbers (see viewtopic.php?p=332369#p332369).
I can confirm it, all combinations of 16bit/32bit environment HDR bit depths and PT/PMC kernels gives now pretty same render output :)
AMD R7-2700/64Gb/RTX2080Ti 11Gb + RTX2080 8Gb/Win10 Pro x64/nV driver 451.67/Poser10, DS4.12, Blender2.79, Octane 4.05 Standalone
> Using RAM Disk with Octane <
abstrax
mac3d wrote:Thanks for the Linux version.
Ubuntu 16.04 64 bit
Sorry for the Linux issues. We are currently looking into it.
