Multipass Render ignoring Octane settings and/or Filepath
spotbot
Not sure what is going on with the multipass here. I've watched the lifeinthrill tutorials over and-and-over again (which are great), but my Multipass is just not behaving in the same manner. It seems to straight-up ignore the File-Path in Octane's Renderer settings... it will create folders, but nothing will render into them... instead they'll render to Cinema4D's Multi-Pass file path. Which then ALSO seems to ignore many of the settings (alphs, file-type, ect. and such) that are set for the layers and just spits out basic C4D-setting layers. It basically behaves the exact opposite of the tutorials...
Any help would be appreciated, thanks!
Oh yes, also: I'm using R19 (but this also happened in R17, R18) and Octane version 3.07 // Windows Workstation
niestudio
Can you post a scene or screenshots of your settings panes?
OSX 10.12.4 | Intel 12 core @ 3.33 ghz | 128 gb ram | NVIDIA GeForce GTX 1080TI | Ubuntu Linux slave with 3x 1080ti
note that Multi-pass saving from external renders is broken in R19.024, and you need to update to R19.053 to make it works again.
ciao Beppe
spotbot
ciao Beppe
Ah ok. Yes, I'm running 19.024 currently. I'll have to update and then post screenshots if it's still broken. Thanks everyone!
cglism
i have ploblem only .Tiff file other file type is create folder and render
if type .tiff file not save to disk
cglism wrote:i have ploblem only .Tiff file other file type is create folder and render
It's fixed on 3.08-RC1.1
