OctaneRender™ for Blender 3.08 - 15.0 [OBSOLETE]
azen
OctaneRender™ for Blender plugin (Currently, only Windows is supported).
This is a TEST version, so be prepared to have some issues. Don't use it for production.
  • New Release Candidate 3.08 engine support implemented. See 3.08 Release Post for more details on the new supported features.
  • Supported multiple uv as how 3DSMax/Maya plugin does
  • No upload for objects that are invisible
  • No upload for shaders that are invisible
  • Display full value precision (up to 6 digits)
  • Refactor blender render pass system.
  • Add new passes (diffuse filter, reflection filter, layer shadow, layer black shadow, layer colour shadow, layer reflection, normal geometric, normal smooth, normal shading, normal tangent)
  • Support stereoscopic camera in preview mode
FIXES SINCE LAST RELEASE
  • Fix disordered preview results
  • Support alpha channel in RenderLayer Node for octane render result
  • Rename "normal vertex" to "normal smooth"
  • Fix multiple other bugs in old render system
  • Use two camera image setting for render mode and preview mode; make it more understandable
  • Fix black screen issue in stereo camera
  • Fix bugs when choosing multiple textures with same name
  • Fix render failure with rename material
  • Fix texture reload issue in image texture node
  • Fix wrong effect for “response type” in camera image
  • Fix anti-virus false positive for window server
  • Fix missing ocean modifier in Linux build
You can read about new features of OctaneRender™ 3.08 here:
viewtopic.php?f=33&t=63219
1. OctaneRender™ Server
Windows
Blender Octane Edition - 15.0 (2.79)
Octane Server - 15.0
