Shadow Pass?
gold
Hello,
I am trying to export a PNG still image to photoshop with a shadow pass.
I'm getting the shadow on the Poser ground plane, or no shadow exported.
EXR format doesn't seem to help.
Is there a way to do this?
thanks
If you are referring to the Shadow pass from the Render Passes node, check out https://docs.otoy.com/StandaloneH_STA/S ... Passes.htm. You will need to assign the shadow source and the shadow catcher to different render layers.
gold
Thanks alot, Paul !
Return to “Poser”
