Like Vray Distance !
BorderLine
Good evening Juan,
Do you think we have the possibility to have something like Vray distance with LW / Octane ?
Thanks !
juanjgon
Are you talking about this feature? https://docs.chaosgroup.com/display/VRA ... istanceTex
Probably these kinds of tools can be done using OSL ...
happymilk
But, is it not the same case of this? :roll:
viewtopic.php?f=36&t=64973
(using the color node instead of the opacity)
Win 10pro 64 | 3 x Geforce GTX980Ti | i7 5930K | 32GB
realistic-design
happymilk wrote:But, is it not the same case of this? :roll:
it is not the same, no. In the example above, it is using "object dissolve" which is not a shader controlled "effect". As Juanjo said, you could do that using OSL and there also might be a way using a LW procedural (using object distance and a gradiant ramp) backed/rasterized into a bitmap at rendertime.
Raphael
Return to “Lightwave 3D”
