Octane OCM Export v1.0
TIG
This is the first release of a new toolset 'Octane OCM Export'
OctaneOCMexporter.zip
(3.8 KiB) Downloaded 521 times
Unzip the .rb file and put it into Plugins...
  • (c) 2011 TIG
    All Rights Reserved.
    THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
    WARRANTIES, INCLUDING,WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF
    MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
    Plugins folder > OctaneOCMexporter.rb
    Usage:
    Menu File > Octane OCM Export... > Camera
    or Ruby Console type: OctaneOCM::Camera.export
    If options are available a dialog opens and you can choose from
    <Current_View>, <Current_Scene> or any other Scene tab-name listed.
    It exports the camera data from the SKP Scene into an OCM file
    suitable to import into an Octane OCS. The file is saved with the model.
    It is named thus "../ModelName[Camera_SceneName].ocm".
    Spaces and Non-ASCII characters are made into '_' in Model/Scene names.
    It includes:-
    eye [pos] [as xyz]
    target [as xyz]
    up [as xyz]
    fov [degrees]
    Menu File > Octane OCM Export... > Sun
    or Ruby Console type: OctaneOCM::Sun.export
    It exports the sun data from the SKP Scene into an OCM file
    It is named thus "../ModelName[Sun_SceneName].ocm".
    It includes:-
    sundir [vector]
    longitude [degrees]
    latitude [degrees]
    day [1-31]
    month [1-12]
    hour [0-24.000]
    gmtoffset [0-24]
    northoffset [0-1.0, i.e. North-angle as proportion of 360]
    Donations:
    by PayPal to info @ revitrev.org
    Version:
    1.0 20110504 First issue.
This allows you to export OCM files of the camera and sun data separately from different scenes and then import them into the existing project's OCS without needing to re-export its SKP geometry again...
Feedback please...
TIG
redmotion
Great job. Thanks for making this, its really helpful on heavy scenes.
I can't give you any genuinely helpful feedback immediately but with a brief attempt at using it, it seemed to work fine. (I cannot advise on accuracy of camera, but will certainly be able to when the next project occurs.)
My only comments might be ability to choose a destination folder and file name for the ocm, but I'm sure you're considering this for a future update anyway.
Thanks again!
win 7 64 | q6600 | 4gb ram | gtx 260 [196] | driver nvidia 197.13 | SketchUp7 | Softimage 2010
win 7 64 | i5-2500k | 16gb | gtx 570 | driver 275.33 | SketchUp8 Pro
juan
hi i would like to know if this pligin works with 3d max, or how to make it work.
thanks!
Portfolio: http://www.tres31.com/site/
http://www.flickr.com/photos/tres31/
sr2 mobo / dual Xeon E5620 3.2Ghz / geforce gtx 480 + geforce 580 3gb msi twin frozr III / 20gb RAM
TIG
This is a Sketchup only tool :(
It's designed to run from within Sketchup and export the SKP's current camera and/or lighting setting in a format that can be used with an existing OCS, without you having to re-export the SKP's geometry - i.e. a quick tweak to a few settings rather than a slower export of everything etc...
So, it is not compatible with any other program, and it could not readily be made so. :cry:
I suggest you pose the question on the 3ds forum and see if there is anything similar available...
TIG
archigrafix
Hum hum! it seems to work fine for me but when I import camera node in Octane how did I make it the "active" camera in the scene???
I have to admit that all this node stuff in Octane is a bit weird for me and there's not much doc or tut on the subject no?
may you help, or show me links related to this subject?
archigrafix
Ok TIG testing I get to know how to connect camera to the right node and it works fine.
however I get a problem with the camera move on a certain simple model.
When I export from SU camera is ok, but as soon as I move (pan or Zoom) the object desappear. Tried everything: reset camera, recenter view and camera zoom picking. but no way. The only thing little special in this model, is it is far from the Origin xyz (no that much however= 250meters)
Any idea why?
TIG
Is your original [exported] SKP model placed near to the Sketchup origin [0,0,0] ?
If not, then when you come to change the OCS camera it can jump wildly as you are far from the OCS origin... :?
TIG
remon_v
wow this is great... whish I had this for Modo aswell.
@ archigrafix, you should try and work with rendertargets.
a tutorial by Radiance about rendertargets:
http://www.refractivesoftware.com/forum ... =21&t=7300
and here's alot of tutorials by Radiant, he also has a tutorial about rendertargets:
http://www.youtube.com/user/MTimtam
Win7 Pro x64, Phenon II 940, 8 GB, Geforce 470 - Modo, Zbrush
archigrafix
thanx remon
I know about rendertarget but it's for last (beta) version of Octane...for now I get the previous stable one..! ;)
thanx
Return to “SketchUp”
