Hi everyone,
I'm having a bit strange problem. I'm using Cinema cloner and the Plain MoGraph Effect to animate some segments appear and disappear.
At the beginning of the animation, the cylinders that I'm using for the animation are at the hight 0.00cm and they are slowly growing to their full height. That's the animation.
So, while previewing the animation in the Octane Live Viewer all seems ok. When the cylinders are 0.00cm they are invisible to the camera but when I try to render the final scene and save it as .psd or any other format, there they are - somehow visible to the camera.
I've attached these two files.
The first one being the Octane Live Viewer and the other one being the Cinema's Picture Viewer.
Octane Live Viewer https://ibb.co/iB97t7
Cinema's Picture Viewer https://ibb.co/nnHAD7
Cheers
Cinema 4d Picture Viewer doesn't match Octane Live Viewer
- nickscrown
Have you checked with Standard renderer?
- nickscrown
Hi aoktar, yes I have. The standard and the physical.
The problem ONLY forms when using Octane.
- oneyedog666
Hi. Did you find a solution. I am having the same issues.
thanks
thanks
Send an example scene for your issues.
