Texture like pointiness on Cycles 4D
Tijack
Hello,
I try to find a way to have colors on a volume depending of the "pointiness" (like on Cycles 4D)
This effects give us something like this :
It's different of the subsurface scattering, cause you can ramp the color as you want.
(Am I clear ?)
Any ideas ?
in Octane you can use only a solid color in Scattering medium node, but you can use a mix material with a dirt shader in amount to blend the scatter, with another material with different or no scatter medium.
Tijack
Humm... have to look at it to better understand.
Thanks for your answer !
