render the Animating Values texture
Andygraph3D
Is it possible to render the Animating Values texture to dial (opacity from 2 textures) in Octane Render ?
If yes with which version of Octane Render ?
thx
Andy
Andygraph3D
So .. i have 2 texture (A + B + picture mask) in poser node and linked to morph dial. When morph is "0" i see only texture A, when the morph is "1" i see texture B.
When render it with poser render not have problem, but i want see the same effect with Octane, is it possible ?
Andy - did you follow the instructions in the manual? When you say "i see only texture A" what do you mean pls? See it in the Poser preview window, the Poser render or the Octane render? Can you pls provide screenshots when you are describing what is happening so it is clearer.
Andygraph3D
Hi Paul, so this is a example ...
Andygraph3D
i have found the solution.., i need remake the node in octane with "Mix tool" because poser octane plugin not converter the "blender node" ...
Return to “Poser”
