3.07-R2 fog thickness issues
1suky1
I started messing around with fog and noticed that for some reason if fog thickness on the environment tag is ~10, the light itself casts a shadow when you are far away.
You can see here how it moves depending on the viewing position.
https://gyazo.com/2442084051707799f340e0d157714035
The way to fix it is to either disable shadow casting on the light itself or to tweak the thickness until the shadow fades out or something.
I guess this is a bug? I don't see how this could be a "feature".
Always try to use values are bigger than scene bounding box radius.
