Hi.
I'm trying to use network render with Houdini 16.5 and Octane. I have installed the last plugin 3.08 and the last standalone in booth PC.
I did the exct same thing with C4D and everyting works fine, but not here in Houdini.
Somone can halp me?
Network Render Houdini 16.5
The current Houdini 3.8.0.0 plugin build is using the 3.08 test4 API, so you must install the Octane 3.08 test 4 Standalone version in the render nodes. You have the links to the correct Standalone version in the same plugin release topic. Probably the latest 3.08 test6 Standalone doesn't work with the current Houdini plugin version.
viewtopic.php?f=102&t=64307
