Unity PBR Viewport vs Export vs Octane Render
Moderator: ChrisHekman
joel.penner
First, thankyou for your hard work creating this, integrating with Unity, and offering a free version. :)
https://imgur.com/a/oG7Ut
In the above link are two different Unity3D scenes. One is an unedited demo scene of the OTOY spaceship, I might have moved the camera just a little bit. The other is a project I'm working on. The PBR Viewport in Unity is much too dark and significantly does not represent the final render. The good news is, the Octane Render screen looks like the exported image from the PBR Viewport, but that really doesn't help me when I'm trying to work directly in Unity.
* Unity 2017.3.0f3
* Octane Plugin Version: 1.1.0.1223
* Octane version: 3.07 (3070007)
Hardware is Asus GeForce GTX 1060 6GB
Let me know if there are any settings you need.
paride4331
Hi joel.penner,
I think you should check Gamma match or response in your Octane Unity imager
https://docs.otoy.com/UnityH/UnityManua ... Imager.htm
Regards
Paride
ChrisHekman
It appears this is a gamma issue with the drawtexture function provided by unity that causes the viewport to be darker than unity and the octane interface.
We'll take a look at it.
joel.penner
Ok, thankyou very much! If there's anything more I can provide to help out, let me know.
rappet
joel.penner wrote:..., but that really doesn't help me when I'm trying to work directly in Unity.
Hi JOel,
Is this what you are saying:
Is it possible to import an ORBX file into Unity and use it in Unity directly without the Octane Render plugin viewport?
because that is what I am trying to find out?
I have seen this youtube vid; https://www.youtube.com/watch?v=ATWFVViiiJc&t=182s
but that shows the ORBX as a proxy in Unity and rendered in the OR plugin viewport...
but when mkaing a gameplay in Unity (without using OctaneRender pugin viewport), then the ORBX is not to be seen/used as materialised object(s), or is it?
because that would be awsome.
greetz, rappet
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
Return to “Unity”
