Hi all,
I was wondering whether the GTX 1080 running on a Mac is compatible with the latest standalone/plugin versions of Octane Render. I've got all the latest NVIDIA drivers for macOS High Sierra 10.13.2.
I've pasted the log here. Any thoughts are appreciated.
Started logging on 29.12.17 22:06:56
OctaneRender 3.07 (3070007)
Scene created in plugin version 3030301
Scene plugin version is older than version:3.07-R2
Plugin will convert the parameters of displacement texture.
Animated attributes should be changed by manually!
CUDA error 700 on device 0: an illegal memory access was encountered
-> kernel synchronization failed
device 0: preview failed
-> failed to deallocate device memory
-> could not get memory info
-> failed to clear linear 2D device memory
-> failed to allocate device memory
device 0: failed to upload data texture 23 of context 1
--------------------------- EXPORT LOG ---------------------------
-> failed to load symbol data to the device(geometry data)
Create Materials....
Export materials time= 278.592 ms
Collect objects time= 9.179 ms
Mesh creation time = 248.819 ms.
Tried to access pin via an invalid ID P_TRANSFORM (243)
Tried to access null node pin
MB:0/0 ST/MOV:0/1 Nodes:49 Tris:0 DispTris:0 Hairs:0 Meshes:0
VRAM used/free/max:1Mb/7.629Gb/8Gb Out-of-core used:0Kb total used RAM:17.852Gb
Total export Time = 565.875 ms
<<< Render failure detected!!! >>>
Please check render statistics to solve the problem.
Device:0 TotMem:8Gb rtData:2Kb film:1Mb geo:0Kb node:0Kb tex:0Kb unavailable:379Mb
