Camera tiles in 3dsmax
HHbomb
Hi, I never need this for now. But is there a way in max plugin to split render in several tiles for Hirez render ?
paride4331
Hi HHbomb,
I think you should use some 3dsMax script.
Regards
Paride
thekwen
In viewport configuration (regions) you should be able to manage a camera blowup.
HHbomb
Hi thekwen , thanks for answer but blowup don't seem to work with octane render.... If you can, please tell me how :-)
paride4331
Hi HHbomb,
it doesn't work; maybe asking to developer, they could. I will ask them.
Regards
Paride
HHbomb
Thanks, It seems to work in C4D.
thekwen
Hello, did you find a solution to this problem ?
HHbomb
Hi, no.
thekwen
Did you try to use lens shift ?
HHbomb
Hi, yes lens shift works fine ( when I finally think to remove vignetting... :oops: )
Now I just need to understand why lens shift is not animatable, so "we" ( somebody ) can make a script to automate the render.
Return to “Autodesk 3Ds Max”
