Octane default settings loss
Goodmorning, I've just installed Cinema 4D R19 and Octane Render 3.07 R2. I've set all the windows layout and set the default interface, also octane settings, and saved as a "New.c4d" file in the C4D installation folder. But every time i open Cinema 4D, the Octane settings resets as default.... why?! This didn't happen with the previous version. Am i doing something wrong? Thanx
- RJMEngineering
You need to open the prefs and open the “other folder” and copy that into the same location in the R19 prefs other folder, that copies all setting over including cache setting, Profiles etc... and the Octane Presets.
C:\Users\Name\AppData\Roaming\MAXON\CINEMA 4D R18_12345678\ and copy to
C:\Users\Name\AppData\Roaming\MAXON\CINEMA 4D R19_12345678\ pasts here
I know as just done the same!
Thanx RJMEngineering, but i don't have R18 anymore, but thats ok, i've done a clean install of Cinema 4D R19, then set every settings/viewportlayout/etc and also octane settings. But everytime i open Cinema 4D (also an existing file) the octane settings are all resets
Thanx
Thanx
