Can Octane run on a Different GPU?
I am trying to get Octane Standalone to run on a separate GPU from Cinema. I have manually set the GPU allocation for each application, however, Octane still runs on the same GPU as Cinema, regardless. Must this be the case? If not, how to solve?
CaseLabs Mercury S8 / ASUS Z10PE-D8 WS / Crucial 64GB 2133 DDR4 / 2 XEON E5-2687W v3 3.1 GHz / EVGA 1600 P2 / 2 EVGA RTX 2080Ti FTW3 Hybrid/ Cinema 4D
Is it fast? Oh, yeah!
The answer is yes, it can, though the results are negligible. Seems that any scene in Cinema using Octane will grind to a halt, making the whole process a waste of time...
here a very informative page on the subject (in French but you can easily online Translate)
http://www.atome451.be/octane-cinema-4d-instances-de-rendu/
pxlntwrk.net
pxlntwrk.net
Yes, and I did soaddol95 wrote:in the octane settings, you should be able to tick the gpu you want octane to use.
Seems like my project is just a monster, in terms of overall objects (which, BTW, includes item tags and pretty much everything in Cinema)... I'm working to reduce the complexity as much as I can, and that might help a bit.
