Interface Request - Adding a few items to the layout
quilmequick
Hi Paul,
Would it be possible to add a few items into the interface for the OctaneRender TAB layout as a default?
Lists, info and statistics panels (maybe just use the Properties, Channels and Lists layout that is the default modelling layout) (having the vertex map list is a must)
Also the top bar (where the Plugin shelf is).
It would really reduce the time spent jumping between layouts.
Quil
You can do this yourself by adding your own Kit which loads after the Octane plugin. Pls see https://docs.otoy.com/ModoH/ModoPluginM ... w%7C_____9 for details.
Return to “Foundry Modo”
