How to import VDB seq
thanulee
Hi, how to import vdb seq from houdini? I only see first frame or nothing at all. Thankz
thanulee wrote:Hi, how to import vdb seq from houdini? I only see first frame or nothing at all. Thankz
You should set frame range by using "File", "start", "end", "digit" parameters. Have you ever tried those?
thanulee
Yes i figured it out, the digits was wrong in my case. Thank u
thanulee
Just keep in mind, unless i put the end frames first i get a crash. Common is to type the start first. So if my start > end frame it just crashes the very moment i input start. And usually houdini starts from frame 1. cheers
orb101
+1 on the crash, I have this issue.
orb101 wrote:+1 on the crash, I have this issue.
Could you describe steps to reproduce crash?
thanulee
Yes, if u have start 0 and end 0, if u go to start and put 1 it crashes. Houdini files start from 1 usually so its very common to change start as first thing.
RJMEngineering
Out of interest, can you retiime a VDB sequence to speed it up?
thanulee wrote:Yes, if u have start 0 and end 0, if u go to start and put 1 it crashes. Houdini files start from 1 usually so its very common to change start as first thing.
i found it. it crashes when you make start value is end+1. I'll fix it!
thanulee
U rock!!! cheers
