Will there be access to your LocalDB?
Moderator: BK
will2power
You have a tab for LiveDB and you have a tab for your presets and the QuickEdit. Will we ever get a tab for our LocalDB in a similar way? It's a bit tedious to import Orbx files to get your materials into the plugin. If you Import them, the only way to save them appears to be saving them as a preset. The only problem with that is that you can't organize your presets and I saw in a previous forum post that apparently you won't be able to. Having access to our Octane Standalone LocalDB might be a worthwhile alternative.
Hi. You can access the LocalDb by Material tab->Import->Users\[username]\AppData\Roaming\OctaneRender\localDb.
Return to “DAZ Studio”
