Specular Reflection Noise
coilbook
HI Are you guys planning to solve the problem in the future with specular noise in reflections including noisy DOF with specular reflected light. If you look at the video (ice ramps in the video ) you can see bright spots on specular material all moving chaotically and this is with static noise ON. It is even worse when specular material and reflections are shown far away. Thank you
specular reflection noise.mp4
(635.91 KiB) Downloaded 1634 times
Hesekiel2517
Hey there, i have a similar Problem. small bright LEDs through a Lens. Is there a trick to reduce Fireflies and excessive noise in the specular Material? I tried GI clamping, Caustic Blur and using the Firefly Filter. Is there anything else i can do?
Thank you in advance
Hesekiel2517
ok, what helped a lot was the reduction of Reflection in the Material and a Absorption Medium
