Hi guys, just a quick one:
Is there a way to make the render window background a solid color? (i.e. Black) if Alpha Channel is ticked on? Instead of the greyed out checkerboard?
This would incredibly help with the project I'm working at the moment.
Thanks in advance
[Quick Question] Background color for render window?
use c4d material with color over a background object. Be sure that you have alpha enabled on kernels.
- stefanmathez
Check this pleasestefanmathez wrote:Hey aoktar, thanks but I can't seem to make it work?aoktar wrote:use c4d material with color over a background object. Be sure that you have alpha enabled on kernels.
- stefanmathez
Thanks solved.aoktar wrote:Check this pleasestefanmathez wrote:Hey aoktar, thanks but I can't seem to make it work?aoktar wrote:use c4d material with color over a background object. Be sure that you have alpha enabled on kernels.
