Mix hdr and sunlight
fabrizio_s
in rhino is it possible to mix hdri and sun?
bye
Bendbox
Hi Fabrizio,
You can set the sun in your Environment Slot and Enable your Visible Environment Pin and plug your desired HDRI into that. Just make sure to enable your Backplate in Visible Environment so you can see the HDRI.
Hope this helps,
Ryan
Win10x64 / AMD Ryzen 9 5900X / 64g RAM / 2 x RTX 3090
fabrizio_s
Hi Ryan,
and thanks for the tip.
I'm just wondering if it is possible to use hdri as sky light in conjunction with the sun light.
bye
fabrizio
Yes, set the Environment->Daylight Environment->Sky Texture to the HDRI map.
fabrizio_s
Thank you, Paul.
I tried it and works fine!
Anyway, I haven't much control over the power of the sky (hdri) because the power value (in the Environment) controls sky and sun light. I would like to increase the light of the sky and decrease the light of the sun.
bye
True. You can increase the brightness of the sky texture by decreasing the texture Gamma.
Return to “Rhinoceros 3D”
