Not sure if it's how I set my project up, but I have received an 'out of memory' error and I have 2 GPUs.
Titan X Pascal and a 1080ti
I have some particles being generated and I'm using a COPY TO POINTS sop to copy some small, 'mountained' spheres to those points.
Houdini says it's 18 million polygons and when I bypass this part of my project it renders fine so I'm thinking Octane is having a difficult time with that many polys.
Any ideas on my issue?
I guess I could just use a material with a little displacement and render the particles as spheres in Octane.
Jim
Out of memory
Your scene can be producing a lot of geometry at extraction time. Be aware that the Copy SOP is not building Octane instances, it builds real geometry from the base object, so it is not a good idea at all use the Copy SOP to instance a lot of complex objects. You should try to use the conventional instancing using the Instance OBJ node or the "instance" point attribute.
Of course, also if possible the best solution is to use the Octane native particles.
- reelinspirations
Instancing fixed the issue. I could not use Octane particles as the objects are small rocks that have displacement.
Still learning...
Still learning...
