automatic update model like shown?
Jorgensen
hi
is it possible to get octane to automatic update the geomtry so it matches what is shown on the screen?
i often set a file with one scene that controls the viewpoints (only camera) and then several others that controls the levels (only layers). but when i shift between these scenes they have no effect on what goes on in octane, other than the camera view - i guess it is so, so octane doesn't reload the model every time.
jorgensen
Hi Jorgensen,
in theory, you should need to press the Octane logo if the elements in scene are different, in order to update the viewport, but, do you mind to share a simple example scene of your typical setup?
Jorgensen
hi beppe
i have this simple model
https://www.dropbox.com/s/2nrqwh1ukut0o ... l.skp?dl=0
where i use scene 00 - 03 to control the layers.
it seems that the "reload" does work - just annoying that one have to confirm every time.
thanks
jorgensen
Return to “SketchUp”
