OctaneRender™ for Blender 3.07 - 13.4 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions.
Here is a basic overview of our Development plans for the near future. Additional feedback is welcome:
  • - Blender Octane Edition 14.x: Integrating Blender 2.79
  • - Blender Octane Edition 15.x: Support for upcoming Octane 3.08 rendering core
  • New stable 3.07 engine support implemented.
  • Fixed crash when switching materials with scenes created in previous versions
  • Fixed OpenVDB problem in linux version
  • Fixed LiveDB thumbnails problem (upside down and bluish tint)
  • Fixed smoke renders problem
  • Added rpath for linux build(try to resolve lib dependency problem in linux)
  • Fixed missing IES texture problem
  • Fixed missing distribution texture problem
  • Added Triplanar projection node
  • Fixed frozen window when querying LiveDB data that is not ready yet
You can read about new features of OctaneRender™ 3.0 here:
viewtopic.php?f=33&t=51679
If you need to see the changelog of current rendering core, or download standalone installer to get network slave and daemon please find it here:
viewtopic.php?f=33&t=62395
1. OctaneRender™ Server
Windows
Blender Octane Edition - 13.4 (2.78a)
Octane Server - 13.4
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v13.4 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v13.4 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v13.4 OSX ZIP
