Hi there,
should be great to have a flag to inherit the general visibility from the nested parent Object tag; or just override with the value coming from the slider (by default as it is now).
I use often object trees... asigning an object tag to the main parent, in order to drive the overall visibility,.. and in the nested childs some other Object Tags to assign.. just a different Layer ID...
in this case the visibility of all these tags, must be driven separately, otherwise they all appears suddenly after parent got higher than zero (because their default is 1)
has it sense?
understandable?
could this feature be useful even for other object tag parameter?
Christian
Heritability of ObjectTag Visibility
