Continuing Authentication problems
Moderator: ChrisHekman
elecman
The Authentication saga continues. It used to work fine, but one day I get this error when loading Octane:
Authentication error: The host application is not signed by 'Unity Technologies SF' (0x43DCBACF)
UnityEngine.Debug:LogError(Object)
OctaneUnity.PluginController:LogErrorCallback(String)
System.Object:wrapper_native_00007FF841CA1680()
Octane.DLL:Api_Init()
Octane.Api:Init()
OctaneUnity.PluginController:Init()
OctaneUnity.EULA:CheckRequest()
UnityEditor.EditorApplication:Internal_CallUpdateFunctions()
I am logged in with both Unity and Otoy.
mojave
Can you please check what versions of both Unity and the Octane plugin you are using and let us know?
Thank you.
elecman
Unity 2017.1.0f3
OctaneUnity 1.1.0.1074
Octane 3.0.7 TEST 6
Xhed
Can you check if your Unity.exe is properly signed? Your log indicated there's a problem with that
- Rick
elecman
Yes, that was the problem. Re-installed Unity and now it works. Thanks :-)
mojave
Thanks for letting us know, I guess it wasn't an authentication problem after all ;)
Let us know if you need anything else.
Return to “Unity”
