Octane Scatter With Animated PNG Sequence in Scale
Im hoping to animate the scatter instances with the scale parameter in a scatter object, right now it does not update in live viewer unless I add dummy keyframes on the texture with a PNG sequence and then check and uncheck the scatter object each frame and then resend the scene. When I render this to picture viewer as a sequence even with update all scene objects every frame on it still does not update and renders the first frame for all frames
