importing octane material into 3dsmax
spillstudios
Hi
Im trying to import an octane material into 3dsmax, it's been saved from maya localdb now I've copied it into the 3dsmax martial library but I can't see it when I open localdb in the render settings layout even though its the same path - any idea how you can import an octane material?
Marc
dual xeon 128gb ram titan X + 2 x 1070
windows 10 - 3dsmax + Nuke
paride4331
Hi spillstudios,
Octane 3dsMax LocalDB path usually should be:
3dsMax C:\Users\(yourname)\Documents\3dsMax\materiallibraries
From Octane rendering 3dsMax plugin 4.41 you can modify the LocalDB path.
To use the material, you have to restart Octane Render 3dsMax, from 4.41 there is a "LiveDB refresh" button.
Regards
Paride
Return to “Autodesk 3Ds Max”
