Hi, i am abit confused about VDBs so i hope u clarify some of my questions.
Firstly i saw in some tuts, that i can scale VDBs in c4d's object mode. Is that a correct way of doing things or should i stick to vdb loader units setup (meters, decameters etc)?
Also, the quality (the voxels i see sometimes as pixels) are strictly related to step length and are not overall object size dependant?
thanks a lot
VDB scaling and step length
Without being specific to C4d, I can tell you that the step length is a fixed distance in meters, which is not affected by the volume's scale. We have experimented with having the step length be a ratio of some sort of the volume's size, but this doesn't work in a few cases.
However this has the effect that if you scale the volume, you must also scale the step length too.
