How can achieve this in Houdini and Octane?
https://www.youtube.com/watch?v=3IVCXIuHDeo&t=206s
I'd like the image to be a sequence too.
thanks
Light Projection Image Sequences
You only need to attach a texture map node to the emission distribution pin. Attached you have a sample scene about how it can be configured in Houdini.
Hope this helps,
Hope this helps,
- Attachments
- 005_projectedLightTextures.rar
- (24.81 KiB) Downloaded 262 times
Thank you for looking into this.
Unfortunately I can't position an image correctly. It skews the image no matter how I rotate the light source. Pointing a light source 90 degrees at a surface does give the correct projection basically.
Also I'd like to use the color of the image, currently it's just a temperature color.
thank you
thank you
