OctaneRender™ for Blender 3.07.t7 - 13.1 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions.
This is a TEST version, so be prepared to have some issues. Don't use it for production.
So far, development for Octane version 3.07 has been progressing well. Until 3.07 is declared stable however, this release of OctaneRender for Blender will be marked as a "Test" version until further notice.
Here is a basic overview of our Development plans for the near future. Additional feedback is welcome:
  • - Blender Octane Edition 13.x: Support for stable Octane 3.07 rendering core
  • - Blender Octane Edition 14.x: Integrating Blender 2.79
  • - Blender Octane Edition 15.x: Support for upcoming Octane 3.08 rendering core
  • New 3.07 engine support implemented.
  • Improve emission effect
    - New emitter options "Visible on diffuse", "Visible on specular", "Cast shadows"
    - Double-sided emitters
    - Transparent emission
    - Improved rendering of non-uniformly scaled emitters
  • Support scatter node and instance IDs
    - Support scatter node
    - User defined instance IDs
    - Support instance range texture
    - Support instance color texture
  • Support Baking texture
  • Support UVW transform texture
  • Support independent UV transform for each baking group
    - Baking UV transform
FIXES SINCE LAST RELEASE
  • - Fixed the problem of scatter node failure
  • - Fixed a crash in the download of LiveDB materials
  • - Fixed the rotation error of infinite plane
  • - Add expected exposure parameter
  • - Deprecate addaptive strength parameter
  • - Add 'TessFace in Preview' option for turn on tessfaces in interactive rendering mode
You can read about new features of OctaneRender™ 3.0 here:
viewtopic.php?f=33&t=51679
If you need to see the changelog of current rendering core, or download standalone installer to get network slave and daemon please find it here:
viewtopic.php?f=33&t=62395
1. OctaneRender™ Server
Windows
Blender Octane Edition - 13.1 (2.78a)
Octane Server - 13.1
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v13.1 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v13.1 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v13.1 OSX ZIP
