Hey Paul,
is it possible to use proxy files within a replicator? When i try to scatter the proxy Mesh nothing happens.
PS: It's definitly possible in Standalone i just have to plug the generated Nodegraph to the Scatter Node
Edit: I found a workaround: I make a proxy file with a replicator inside. Works but would be a lot easier if we could use the replicator directly.
Thanks in Advance!
Replicate Proxy Geometry
Hi - you are right - Proxy ORBX file support does not currently work in a Replicator, and you need to do it in reverse (ie. have the scatter node inside the ORBX proxy).
- Hesekiel2517
Hey Paul,
any News about this? Will it be possible to replicate proxys or even instance them? I have some heavy meshes and it's so nice to put them in proxys. But i have to duplicate them over and over again and so i have to decide between multiple proxys or some heavy meshes in my scene.
Thank you in advance!
Hi. Once I get a solid 2018.1 release done I will take a look at this, as it should be reasonably easy to implement. If you haven't seen it in the plugin in the next month, pls give me another prod about it.
- Hesekiel2517
Hey Paul, thank you in advance. That sounds great!
- Hesekiel2517
Just downloaded the new testbuild: Thank you
That was quick!
That was quick!
