Hair thickness and mograph
Janmansilver
Is it possible to control the thickness of "the render as hair" option in the octane object tag, via a mograph effector? I've done a hack where I use a single cloner set to blend mode (with two splines each with an octane object tag with "thin and then thick hair setting") and then cloning this, but this is very inefficient for working with the model in the viewport.
It's not possible to affect as a parameter for each strands.
jeffthomson
doesn't each strand/spline have a unique id? Even if there was just a way to randomize width or drive via a texture map would be pretty cool
Have you tried it with hair object? It should show thicknesses correctly.
