how can i render an animation using 3dsmax ?? is it the same as usual? when i click on render of 3dsmax i didn't see more the windows of octane by the standard window of 3dsmax of the rendering, is it possible to use instead thatone of octane even during an animation ?
how to render an animation on ORC =???
which is the best way to do it?
rendering with octane for 3dsmax and orc
- paride4331
Hi marco75,
To render you have to use the usual procedure to render in 3dsMax:
setting output parameters in the Common tab (frame, size, etc..) and adding the layers pass in Render Element tab, then launches Render.
You can not render using the Octane Viewport.
About ORC (Octane Render Cloud) https://orc.otoy.com
you will find all the information and answers here:
viewforum.php?f=100
You can send your scene directly to ORC through the 3dsMax Octane Cloud tool in the Tools tab (Render Setup).
My personal advice is to verify that your scene is correct, before sending to ORC, trying to render it in Octane Render SA.
If Octane Render SA will correctly render your scene, then you will be sure that ORC will also correctly render.
This method saves time and money while avoiding bad surprises at the end of your render job.
Regards
Paride
viewforum.php?f=100
Regards
Paride
